Distributed rendering and procedural noise
  • Distributed rendering and procedural noise
    Using Vray 3.00.03
    Having an issue where procedural noise is rendering as black dots. EDIT: looks like it is only procedural noise on the bump thats the issue. On the refraction it works perfectly.
    Ideas? If it's a build issue, is there a way to fix it locally without changing versions?
Name:	distributed_render_ test_incorrect.jpg
    Reel 2016
    Any chance that DR node is AMD and yours is a Intel?
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      They are both Intel machines. I7s.
      With/without embree turned on results in the same problem.
      Reel 2016
        The noise is actually implemented by 3ds Max, we don't have control over it. Maybe try using another noise texture, like Bercon noise?
