the Lens Shift/Tilt, the viewport does not match the rendered image.
  • the Lens Shift/Tilt, the viewport does not match the rendered image.
    Enter a large value for both the Lens Shift/Tilt, the viewport does not match the rendered image.
    3dsMax 2016 + VRay 3.20.02 is used.
    autodesk side problem?
    max2016.zip
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    I had a similar problem with the "distortion" the other day.
    www.robertslimbrick.com
      We are looking into it right now and as soon as we have any information, will update the thread.
      Tashko Zashev | chaos.com
        It is considered as a bug and we have forwarded the files to our developers. We are still not sure where exactly is the problem, in our renderer or in 3DS Max itself.
        I will post here when we have news.
          Thank you for the verification.
          Incidentally it produces also in mentalray 2016.
          oakcorp.net
          v-ray.jp
            Yes , it is the same when render with mentalray.
              I don't think this is a rendering problem, actually. It would be best to report it to Autodesk.
                Did anyone find a workaround?
                Max 2023.2.2 + Vray 6 Update 2.1 ( 6.20.06 )
                AMD Ryzen 7950X 16-core | 64GB DDR5 RAM 6400 Mbps | MSI GeForce RTX 3090 Suprim X 24GB (rendering) | GeForce GTX 1080 Ti FE 11GB (display) | GPU Driver 546.01 | NVMe SSD Samsung 980 Pro 1TB | Win 10 Pro x64 22H2
