Vray DR and Bercon Maps
  • Vray DR and Bercon Maps
    Just to be sure:
    If I want to render shading networks including those procedural maps, those have to be installed on the slaves as well?
    Thx for a roger, or any other info.
    Cheers
    EDIT: even those are on the slaves as well, I get horrible gamma issues. The slave buckets are much much darker. So the trick piping them through vrayHDRI map might help. Didn't test that out yet.
    The question is: as this issue is a Adesk sh... - did they fix this in the max 2016? Does anyone of you experience bad gamma buckets whlie rendering DR on the slave machines in max 2016?
    BTW: max 2014 and latest vray here.
    EDIT II: ok VrayHDRI isn't an option... - works only with bitmaps. I rendered with max camera with exposure control set to vray photograpic. changed the cam to vray cam and turned off the exposure control - no change.
    The buckets of the slave are simply to dark... bad gamma.
    And it has nothing to do with the Bercon Maps... I disconnected them and the prob is still there... it drives me crazy.
    No DR - all works fine
    EDIT III: oh boy. I've found the problem. The blo.. HDRI reflection map was connected localy, not UNC and the bl... asset manager didn't show it up.
    sorry for buggin you.
    Glad to hear you sorted it out
    Let us know if it happens again.
