RAM unload after render taking extremely long
  • RAM unload after render taking extremely long
    I have a RAM-heavy scene (takes about 33GB of RAM peak) which is using displacement.
    When I cancel a render it unloads the RAM at about 20MB/sec according to my estimation from the Task Manager.
    You can imagine it takes ages until the machine becomes responsive again.
    Any way around it? Reasons?
    Software:
    Windows 7 Ultimate x64 SP1
    3ds Max 2016 SP4
    V-Ray Adv 3.60.04
    Hardware:
    Intel Core i7-4930K @ 3.40 GHz
    NVIDIA GeForce GTX 780 (4096MB RAM)
    64GB RAM
    DxDiag
    I used to get this with vray 2.x for Maya. Could take 5 minutes to unload the scene from RAM*
    Haven't run into the issue with 3ds Max / vray 3.0 but I probably also don't go overboard with displacement like I used to as a beginner. Smaller map sizes, more optimized settings (basically just the defaults with 32 subdivs)
    *would the reason it takes so long to unload be because it's not actually RAM per se, but the system page file? caused by going over the amount of actual RAM the system has? Though my page file resided on my SSD...
    Though in your case I see you have 64gig and only 33 in use, so page file use probably isn't anything to do with it
      Thanks for your reply.
      I propably don't go over board with the displacement settings but I need fine settings for my stuff to work
      Software:
      3ds Max 2016 SP4
      V-Ray Adv 3.60.04
      Hardware:
      64GB RAM
      DxDiag
        I've been having this problem too, but never thought to check the speed of the RAM.
        Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
        www.robertslimbrick.com
        Cache nothing. Brute force everything.
          Did you have many render elements? I've experienced the same issue and it seems to start happening when I have lots of render elements.
            Speed of the RAM wouldn't be relevant for something like this.
              Well I do ahave a few, but nothing out of the ordinary.
              Anyways the project is over now, I need to analyze that further when I got time.
              Software:
              3ds Max 2016 SP4
              V-Ray Adv 3.60.04
              Hardware:
              64GB RAM
              DxDiag
                Best to get us a scene to look at. There are a few parts of the V-Ray code that may produce this effect, but I don't know which one happens in your scene.
                  Just sent an eMail to you, Vlado, containing the download link. ("User: Art48; Thread: RAM unload after render taking extremely long")
                  Software:
                  3ds Max 2016 SP4
                  V-Ray Adv 3.60.04
                  Hardware:
                  64GB RAM
                  DxDiag
                    I got the scene thanks! I guess part of the problem is that it does take a lot of memory to render to begin with; I'm wondering if there's a way to make that better first.
                    How much RAM do you have in your machine?
                      I just rendered this scene, and I have 64GB RAM installed, and the final scene when rendering was at about 55 GB (that is total ram consumption according to the task manager), so there's still plenty of room.
                      I know stuff canbe optimized, but I got no time for that, and RAM is there to use it
                      Software:
                      3ds Max 2016 SP4
                      V-Ray Adv 3.60.04
                      Hardware:
                      64GB RAM
                      DxDiag
                        Yeah, however I don't have 64 GB So I've got no choice but to optimize.
                        If I had to guess though, I think the slow release comes from the displacement, but I need to confirm it.
                          Oh, alright ^^
                          Anyways it would be awesome to have this fixed somehow since it doesn't allow for a very interactive workflow, and displacement rocks and we use it often
                          Software:
                          3ds Max 2016 SP4
                          V-Ray Adv 3.60.04
                          Hardware:
                          64GB RAM
                          DxDiag
                            It's definitely a displacement issue in my scenes.
                            • #15
                              I've experienced my share of very slow RAM unloads too, with other projects and as far as I remember also used displacement. I also wondered why RAM was so slow to unload, can't it be just 'cleared' or 'deleted' or something at render end.
                              A.
                              www.digitaltwins.be
