Vray RT - GPU don't stop running as long as Vray license service running
  • Vray RT - GPU don't stop running as long as Vray license service running
    Hi
    as the title say if I run a VrayRT render, the gpu never stop calculating (heating) as long as Vray license service running... Bad thing.
    Have you modified Max time or Max path/pixel parameters to limit the RT calculations? If you are using the default RT setup, these parameters are set to zero and you have to manually stop the rendering process with ESC or the VFB Stop button.
    Tashko Zashev | chaos.com
