Can´t finish or cancel rendering
  • Can´t finish or cancel rendering
    i have a scene(still), with some geometry and a landscape, which has displacementmaps.
    The rendering is starting and rendering, but if i want to cancel or when the rendering is done, it hangs up.
    Are you trying to cancel during the light cache calculation?
      no, it´s in the finale rendering.
        Would it be possible to send us a scene that reproduces the issue to support@chaosgroup.com ?
        How much memory is taken during the rendering process ? Probably the unloading process is too long.
        Tashko Zashev | chaos.com
          i found out that it is work, if i use the subdivision displacement method. But i was more happy with the optical result i got with the 3d mapping option.
          I have 32gb ram. At rendertime it is almost full.
            Does it help with static geometry? (I had a scene with the same problem and changing my geometry type did help.)
              Thanks, i will try that.
