I've got a pflow disk cache with 800,000 particles and I'm using the Shape Instance modifier as a post-cache operator. It works great in the viewport but vray can't seem to render it. I get this error:
Seems to happen regardless of what "Geometry" render typ I use (Single mesh, Multiple meshes, mesh per particle).
Code:
[2015/Sep/4|13:34:04] Extracting frame data from FrameParams. [2015/Sep/4|13:34:04] Extracting frame data from VRender Environment params. [2015/Sep/4|13:34:04] Extracting frame data for fields. [2015/Sep/4|13:34:04] Extracting frame data from node (PhysCamera001). [2015/Sep/4|13:34:04] Rendering from camera PhysCamera001 [2015/Sep/4|13:34:04] Setting up frame region. [2015/Sep/4|13:34:04] Clearing previous contents of frame buffer. [2015/Sep/4|13:34:04] Calling beginFrame(). [2015/Sep/4|13:34:04] Entering beginFrame(). [2015/Sep/4|13:34:04] Setting RenderGlobalContext. [2015/Sep/4|13:34:04] Broadcasting NOTIFY_RENDER_PREEVAL. [2015/Sep/4|13:34:04] Updating the tone operator. [2015/Sep/4|13:34:04] Preparing camera sampler. [2015/Sep/4|13:34:04] Calling update(). [2015/Sep/4|13:34:04] warning: Bitmap pager is enabled; rendering might be slower [2015/Sep/4|13:34:04] Updating scene materials for time=0 [2015/Sep/4|13:34:04] Loading bitmaps for "" [2015/Sep/4|13:34:04] Updating "" [2015/Sep/4|13:34:04] Loading bitmaps for "Snow2" [2015/Sep/4|13:34:04] Updating "Snow2" [2015/Sep/4|13:34:04] Loading bitmaps for "Map #109" [2015/Sep/4|13:34:04] Updating "Map #109" [2015/Sep/4|13:34:04] Loading bitmaps for "Map #121" [2015/Sep/4|13:34:04] Updating "Map #121" [2015/Sep/4|13:34:04] Loading bitmaps for "Map #121" [2015/Sep/4|13:34:04] Updating "Map #121" [2015/Sep/4|13:34:04] Loading bitmaps for "Matte" [2015/Sep/4|13:34:04] Updating "Matte" [2015/Sep/4|13:34:04] Loading bitmaps for "" [2015/Sep/4|13:34:04] Updating "" [2015/Sep/4|13:34:04] Preparing objects [2015/Sep/4|13:34:04] Updating object PFS_FineSnow001->PFS_FineSnow001 [2015/Sep/4|13:34:04] Number of particles for "PFS_FineSnow001->PFS_FineSnow001" is 0 [2015/Sep/4|13:34:04] Updating object PFS_FineSnow001->Event 005 [2015/Sep/4|13:34:04] Number of particles for "PFS_FineSnow001->Event 005" is 800000 [2015/Sep/4|13:34:16] error: UNHANDLED EXCEPTION: Preparing objects Last marker is at ./src/vrayrenderer.cpp, line 3259: Preparing camera sampler
