Can't color correct VraySky map
  • Can't color correct VraySky map
    Does anybody know how to properly color correct a VraySky map? I tried to use it with Max's Color Correction node to tone down the blue shadows but as soon as I do this the render becomes dark as if there's no VraySky in the environment slot. This is with the latest official version of Vray on Max 2016 SP1 EXT1.
    If my memory doesn't lie, I remember some time ago that I did this and there weren't any problems using it in conjunction with the Color Correction map but I don't think this was with Vray 3.
    Here are a couple of screenshots:
ID:	882784 Click image for larger version
    EDIT: Forgot to mention that this is rendered with VrayRT in CPU mode. I now tested the production renderer and everything works like a charm! Is this a limitation or a bug? In the supported features page of RT it says that it does support Color Correction map and VraySky.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    3ds Max 2023.2.2 + Vray 6 Update 2.1
    AMD Ryzen 7950X 16-core
    64GB DDR5
    GeForce RTX 3090 24GB + GPU Driver 551.86
    I would also love for this to be supported. It makes more creative sky setups possible but not with RT
      It will work for the next SP.
        Awesome!
        Aleksandar Mitov
        64GB DDR5
          yasssssssssssssssssssssssssssss
            you can also try using a vraycomptex, set to multiple or add. and use a vray colour node.
            I haven't tested this with RT though
