Hi, I tried searching for this but couldn't find anything. I'm trying to use more than one vraysoftbox map in a scene, but it seems that the values for the hot spot/ dark spot are instanced or locked to each other, even though the actual maps are not instanced. The base parameters are fine, just the hot/dark spot values. It's driving me crazy, can't figure out a way to fix it. I just installed Vray 3.20.03 to see if it would fix it, but did not. With Max 2014.
Vraysoftbox - hot Spot / dark Spot values instanced
Tags: None
I'm interested to find out why the hot Spot / dark Spot values are instanced across multiple copies of the map too. I've had the same problem as you when I tried to use the VraySoftBox map in a particular project. I gave up on it because of this problem and ended up painting my own softbox textures. Furthermore, the tracks of the map's parameters in Curve Editor are bugged and show "???" instead of their names:
Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
Would it be possible to send us a sample scene which holds the issue with the instanced values since we are now able to reproduce this issue into our environment?
Let us also know the exact V-Ray/3DSmax versions/service packs that you are using?
Regarding the unreadable values (???) of the Softbox texture under the Curve Editor - we got the same thing here so we are going to report it into our system.
Please see attached a simple sample scene I made that exhibits the bug with the instanced parameters (VraySoftbox_bug.zip). Its made with Max 2016 SP1 EXT1 and Vray 3.20.03. Attached is also another screenshot showing the problem.
VraySoftbox_bug.zip
It looks like not only hot Spot / dark Spot values are instanced but the Gradients parameters as well, as you can see from the screenshot. When I go into the map of the blue softbox, it shows that there are no vignettes applied but there clearly are. This is because I worked on Softbox 2 first (the blue one) and then on Softbox 1 (the yellow one). Looks like the map remembers which softbox was worked on last and it shows these parameters across all softbox maps in Max.Last edited by Alex_M; 14-09-2015, 06:48 AM.Aleksandar Mitov
96GB DDR5
Hi, here's a quick test scene to demonstrate the problem. I have four unique vray lights with 4 unique softbox maps. And still the values for hotspot/ dark spot change across all maps. The values for the tint color change too, but only affect the appearance of whichever map is newest. I have Max 2014 SP5 and Vray 3.20.03, but this problem showed itself in an earlier version of Vray too, 3.something.. I will email this to support as well, thank you.
Softbox problem.zip
Thank you Svetlozar. If you guys are working on the Softbox map, I was wondering if you could take a look at something else. Would it be possible to change the gradients so that when you edit a slider you can use the color picker/editor instead of just decimal rgb values? I don't find it easy to use - but that could just be me.
It would be better to post this request into Wishlist section here:
http://forums.chaosgroup.com/forumdi...s-Max-Wishlist
