Wee bug with hair and fur modifier and mr prim - no info in the velocity channel
  • Wee bug with hair and fur modifier and mr prim - no info in the velocity channel
    Heya folks,
    I was trying to get velocity information for a hair and fur modifier using mr prim and the vray hair shader and there was nothing appearing in the render element - It turns out that you need to go into the object properties of your hair emitter object and use the old 3dsmax motion blur in either object or image mode instead of none to get the modifier to output info for the velocity element - would it be possible to get vray to do this in the background if it ever sees a hair and fur modifier?
    Cheers!
    Jonh
    We'll make a note about it into our system and will inform you when we have some updates on that matter.
      No need for updates at all - it worked fine with that one extra setting and shot already gone out
