I have a plane and I when I try to use Autograss or Forest Pro, nothing renders. The plane does, and everything else in the scene, but not the Autograss or Forest Pro element. Very strange... Any clues? I am trying to render a 360 camera view, so I change the camera, in the V-Ray camera dialog, to spherical and 360, but other than that, the scene is pretty normal.
Strange Problem
Strange Problem
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
does forest pack have this limit to camera feature enabled? maybe it doesn't play well with spherical views...
I was using Autograss, which wasn't working, so I tried Forest Pro. The site is large, so I can't export it and import it again. Either the geometry broke, or the spherical camera is the issue.Bobby Parker
phone: 2188206812
- Windows 11 Pro
All the normals are correct abd FP didn't give any warnings; it just didn't render any grass.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Man! You just saved me, thanks!Originally posted by Schellicon View Posti had this Problem sometimes.... nearly happens every time i use splinemodeling+surface mod....
just make a new object "A", collapse it, and attach the old plane"B" to "A", go into subobject , delete "A"
if its still not working , just flip the faces
don`t ask why, but it solves the ProblemBobby Parker
phone: 2188206812
- Windows 11 Pro
