I can see things under the surface through SSS...
  • I can see things under the surface through SSS...
    I might be thinking of another renderer but... I have some teeth, eyeballs and separate Eyelids (with SSS as well) that are showing up just under the skin of a face. I thought there was a toggle to turn off other object being seen through SSS? In Modo I think it's called "Same Surface only." I thought it was in Vray as well? If not, how would you solve this issue?
    Galen Beals
    Animator/Technical Director
    Portland, Oregon
    What mode have you set for the Single scatter component ? Is it Raytraced Refractive ?
    Could you post any examples or a scene file ?
    Tashko Zashev | chaos.com
