Frame Stamp not working as normal
  • Frame Stamp not working as normal
    I am using this as my frame stamp
    " Location | June 21 | Time: %frame | Proposed Layout"
    and my scene only has 24 frames so when i am on frame 9 i expect to see the stamp as Location | June 21 | Time: 0009 | Proposed Layout"
    buy I am not, i am getting the stamp ghosted and 219 appearing - this only happen since upgrade to 3.2
    Please advise - need this stamp on almost 60 images, and in no mood to have to do that in PS.
    thanks
    T
    update:
    Reset to scanline, then back to VRay, still giving crazy numbers, e.g Frame: 00073 when there are only 24 frames in scene,
    I have sent file to support.
    Accept that some days you are the pigeon, and some days you are the statue.
    We logged the issue in our bug tracking system. Thank you for the feedback.
      Actually saw somewhere in this forum that its possible to access the frame stamp via maxscript, if that's the case you can add the current frame via mxs.
      edit - found it: http://forums.chaosgroup.com/showthr...tamp+maxscript
        Is this bug still present in 3.4? been having trouble reading my frame stamps for a while now, but if it's just the frame# messing up, i'll remove that from the stamp to get the relevant info i need then.
        | LinkedIn | Twitter | JCanimator.com |
          Shouldn't be an issue for 3.4. Can you send us the problematic file to support@chaosgroup.com ?
          Including short description of the problem.
          Tashko Zashev | chaos.com
