Strange Material Noise
  • Strange Material Noise
    What the heck! What would cause this? I can raise my setting to get rid of it, however, my render times skyrocket. Everything else in the scene looks good.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    It's on the far left wall as well. Looks weird. Do you still get it if you switch of the DOF?
    Unrelated, are you sure those light fittings in the ceiling are the correct scale?
    Kind Regards,
    Morne
      My guess is a mesh light, or a light bouncing off something on to that wall.
        Check your renderpasses to see what causes this. I had it too once. It was in my lighting pass. Never got rid of it though.
        A.
        www.digitaltwins.be
          I ended up increasing some subdivs, which mostly cleaned it up. I'll dig deeper today.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            could be reflection cutoff on some material in the scene. see if it goes away with refs disabled. alternatively check the cutoff on the light, although i believe that only affects shadows.
