exclude HDR light dome reflection from the vrayplane
  • exclude HDR light dome reflection from the vrayplane
    I'm trying, without success, to get a ground plane to reflect objects in the scene but not to reflect the HDR map applied to the Vray HDR dome light.
    How can we achieve this?
    The Vrayplane has a matlwrapper to it.
    With a little bit of magic...
    Change the first line to whatever your light is select your ground plane and run this maxscript
    theLight = "VrayLight001"
    vrayaddtracesets $
    append (vraygettracesets $).reflect_exclude (getnodebyname theLight)
    Maxscript made easy....
    davewortley.wordpress.com
    Follow me here:
    facebook.com/MaxMadeEasy
    If you don't MaxScript, then have a look at my blog and learn how easy and powerful it can be.
      Thanks, however I've got: -- Unknown property: "reflect_exclude" in undefined
      theLight = "VRayLight002"
      vrayaddtracesets $
        Did you select your ground object?
        Follow me here:
ID:	858744Yes, but may be I didn't use the script properly.
          Here is a copy of the screen.
            Works here.
            Put all the script in the script editor (not the maxscript listener) and press Ctrl+E.
            Follow me here:
              thanks, can it be a problem with the max version? (2014).
              The script run fine (no error) but the plane still have the reflection of the HDRI visible.
              The plane is selected when CTRL+E is press.
                It looks like the Reflection include/exclude lists doesn't work with matte objects set with Wrapper material. Probably there is a bug. Could you try to use the matte properties from the right click V-Ray object properties instead. This approach works better according to my tests.
                Tashko Zashev | chaos.com
                  Is there a button hidden somewhere for this function? I can't see it on the User interface.
                    No, there is no option in the UI to do that.
                      Maybe if you turn on 'Dim distance' for the ground plane material it will ignore the dome light.
                      Greg Geffert
                      Spectrum Brands
                      www.greggeffert.com
                        thanks to Dave and its magic maxscript!
