LC Slow to kill
  • LC Slow to kill
    I had this problem in the past, however, I don't think that is was ever resolved. I received a MAX model; the previous person used V-Ray, and I am using MAX 2015 and V-Ray's newest beta. It's taking 3-4 minutes to cancel a render; it gets stuck at "Building light cache..." What is causing this? The only special thing I have is AutoGrass, which I don't think is the issue.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    4 minutes and 34 seconds, to be exact. Very frustrating.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      it could be autograss..... maybe it's the old version for 2.5 .... I reinstalled mine for an old project and it's working well
      show me the money!!
        use vray convert.... I had some issues with "blend " material and lc
        show me the money!!
          Wasn't Autograss; it does it with Forest Pro, too. I built this new scene by scratch, so I know every material.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            try with the new beta released today
            Kind Regards,
            Morne
              I will, thanks!
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                No go! Still takes 5 minutes to cancel a rendering, which is rather frustrating.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  It is, without a doubt, a displacement issue. If I globally turn displacement off the problem goes away.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Also, cancel is grayed out now, however, esc worked.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      What are the displacement settings? Does it get better if you decrease them?
                      Is there a chance to send us simplified version of the scene for investigation?
                        Actually, I played with the displacement settings and the problem went away. I think that the displacement resolution did the trick.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          Glad to hear you figured it out.
                            I use a script for my roof and the default displacement resolution is 3000. After I set it to 512, it starting acting much better, however, this was never the case prior to the beta.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
                              It might be a good idea to investigate what's going on, it may be a bug or something.
