itoo colors
  • itoo colors
    hello,
    im using forest pack pro and HQ1 Plants.
    but the Colors of the flowers (blue and red) get burnt out on some bushes (you can see in the pics).
    the materials are vray.
    i have played around with rendersettings, but it is not getting better
    please can you help me
    thx Thomas
    Is every material in the scene a Vray Material? Try running this converter script on your scene...
    http://www.motivacg.com/en/material-converter/
    Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
    www.robertslimbrick.com
    Cache nothing. Brute force everything.
      thank you, yes all vray, no change after running the script
        It's because the HQ plants (nothing to do with ForestPack), has on some of the flowers in the Bitmap output, instead of rgb level or rgb output = 1, they have it on 1.5 and that is creating the blowout. Just bring it down to 1.
        In material editor go to the bitmaps in the diffuse for the flowers, then check output rollout
        Kind Regards,
        Morne
          Would it be possible to post or send reproducible scene to support at chaosgroup.com ?
          We will also need the exact 3DS Max/V-Ray/ForestPro versions.
          Edit: I see Morne has a good proposal for this issue. Let us know if this fixed it.
          Tashko Zashev | chaos.com
            thank you very much Morne, this was the problem - it is solved!
