VRay warning after downloading latest version
Do you have a maxstart.max file? If yes, then simply re-save it with the new version. You will have to click "yes" in that dialog to make V-Ray turn on some of the new features like the new sampler, sRGB color space etc.
VladoI only act like I know everything, Rogers.
I have a different maxstart.max for every project, so I will have to modify them all. I think it would be better to add a check box somewhere and put the message in a readme file.Last edited by jstrob; 18-12-2015, 07:42 AM.
__________________________________________
www.strob.net
Explosion & smoke I did with PhoenixFD
Little Antman
See Iron Baby and other of my models on Turbosquid!
Some RnD involving PhoenixFD
Well, you can suppress the message if you type in the MaxScript listener (this would be equivalent to selecting NO in that dialog):Code:setVRaySilentMode()
VladoLast edited by vlado; 04-01-2016, 03:28 AM.I only act like I know everything, Rogers.
- Likes 1
I too would like to know how to suppress this message when opening every file.
Oops, I see it. I forget this Forum sorts backwards. I was looking at the bottom thread not the top one.
FYI, I read the ReadMe and didn't see it mentioned.
Thanks.Last edited by RobH22; 07-01-2016, 10:15 PM.------------------------------------------------------------
V-Ray 6.20.06, 3ds Max (3D Studio thru Max 2025), GIGABYTE X570 AORUS Master Motherboard, Ryzen 9 3950x CPU, Noctua NH-D15S CPU Cooler, 128 GB G.SKILL Trident Z Neo DDR4 Ram, NVidia RTX 4090, Space Pilot Pro, Windows 11, Tri-Monitor, Cintiq 13HD
Autodesk Expert Elite Member
Originally posted by RobH22 View PostOops, I see it. I forget this Forum sorts backwards. I was looking at the bottom thread not the top one.
Great, thank you. Now give is use same kind of dropbox to turn off the warning about the new render algorithms....lol....
Regards------------------------------------------------------------
Originally posted by RobH22 View PostGreat, thank you. Now give is use same kind of dropbox to turn off the warning about the new render algorithms....lol....
Regards
www.strob.net
Little Antman
