V-ray Physical Camera problem
  • V-ray Physical Camera problem
    Hello to all.
    I have noticed that in the official help of vray, there is an error.
    The guide is the command to create a Physical Camera, is " varycreatVrayPhysicalCamera() " but it is wrong,
    the correct command is " varycreateVrayPhysicalCamera() "
    Is there a way the most 'fast to create a V-Ray Physical Camera?
    -if I use the Physical Camera of 3ds max 2016 whit the Physical expousure active, it will have the same result in giving the V-Ray Physical Camera?(of course with the same parameters)
    sorry for my poor language
    thank you all, I hope I was helpful
    Thanks for the pointer about the docs, I fixed the error.
    You could bind the vrayCreateVRayPhysicalCamera() command to a button on a toolbar, if you want to access it faster.
    The Physical Camera in Max 2016 will produce very close results to the V-Ray physical camera (there is one minor difference in how the ISO exposure is calculated).
      thanks for help!
