DR crush problems
  • DR crush problems
    Hi guys i have a issue.
    Servers are machines that already have 4 or 5 years. HP computers are dual Xeon LGA 1366 V1
    For some reason since v3.2 these are very unstable and often make 3Dmax crash completely. With or without maps.
    Currently I wanted to discard it was a problem with the scene using an equal worsktation that I'm using. This side worstation the use of slave and has no problems with DR.
    It happens with all the scenes that I'm using.
    The configuration of HP are 8 trays.
    Dual Xeon QuadCore 2.4.
    32g ddr3 1333
    500g HDD 7200
    Windows 7 64
    Dr've tried it with and without the options it gives DR window.
    Excuse my English but is translator.
    try uncheck embree and see if this issue still happens. Also I suppose they have enough ram in them?
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Hi Morbid!
      I try that!
      Yes.. each machine have 64g.
        Could you confirm that you are using the same V-Ray version on all of the machines? Also have you tried the latest 3.30.03 build?
        Would it be possible to send us vray_log files and 3ds max dump files after the crash? Does the issue persist only when doing distributed rendering, can you reproduce the crash on a single machine?
          Hi!! Zdravko
          Yes its the same build for all machines and is the las 3.30.03.
              Yes, of course.
              give me a few minutes
