Render Mult: seems to have stopped working
  • Render Mult: seems to have stopped working
    I'm working on a scene lit by a HDRI dome. Earlier when I was setting it up, I was fiddling with Render Mult: at a setting of about 1.5 to be the brightness I was looking for. However now, it doesn't seem to make any difference where its set. I have it all the way up to 10 and it looks the same as set to 1. My Inverse Gamma is at 1.5 at the moment. I'm using 3.30 and the "default" settings with Brute Force. Camera is set 1/30sec, 160ISO F/8. Everything is the same as when I started. No idea why I can't increase the intensity of the dome source.
    Thanks.
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    Maybe you made a copy in the material editor of the HDRI and you're chaning the wrong one's values?
    Kind Regards,
    Morne
      That's what I wondered too, but the material was active. So what I ended up doing is to delete the dome and the material and then importing those things from an earlier version of the file that was working. That seemed to fix it. I still don't know what was up with that. Probably something stupid I did!
      David Anderson
      Software:
      Windows 10 Pro
      Hardware:
      Puget Systems
      TRX40 EATX
      128GB RAM
        We could check what's going on if you send us the scene
