volumegrid jitter loading vdb files
  • #16
    Yup, we got it - we didn't handle all cases - you can check tomorrow's nightly for the fix. Thanks for finding this out and reporting it!
    • #17
      Thanks to you guys!
      I'll update in the next few days.
      Cheers,
      fede
      KCTOO - Directors
      • #18
        Hi Svetlin,
        Am I able to get a nightly with this jittering fix (who to email?) The VDB jitter issue has come up again for me.
        Thanks
        • #19
          Hey,
          You can try a nightly if you use Phoenix or a stable if you want to check the fix in V-Ray as well - you need to contact support@chaosgroup.com for permissions.
          Cheers!
          • #20
            I've run into a similar positional jitter problem with using the volumegrid playback speed to render the a sim at half speed using the vdb's velocity channel. Is this issue fixed in 3.30.04?
            thanks,
            V Miller
            • #21
              Hey,
              You should get 3.30.05 for the fix.
              Cheers!
              • #22
                Originally posted by kagemaru View Post
                As a side note, if i read then re-write the exact same vdb with houdini it works fine.
                Which ought to provide an indication of where the issue lays.
                I tried scripting a shading converter between fume and grid, and failed so badly it still hurts to think about.
                Let's hope this problem is ours to fix. ^^
                Lele
                emanuele.lecchi@chaos.com
                Disclaimer:
