Unhandled exception
  • Unhandled exception
    error: UNHANDLED EXCEPTION: Broadcasting NOTIFY_PRE_RENDER
    Last marker is at ./src/vray.cpp, line 2007: VRay::beginSequence, clearing render settings.
    What's up with this?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    After several attempts, I gave up and went to a backup. The only difference between the bad and the good is after I converted bitmaps to HDRI something bad happened. Also, this is one I was having normal issues and support said that it was the roof, however, I just pulled a different camera and I don't get the normal error anymore.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      The HDRI converted shouldn't break the file in any case, there might be something else.
      Have you tried to run the HDRI converter on the backup file?
        The job is done, so I can't text it. My current job was converted and all is good.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          I know you said it wasn't the converter, but this is another job, I converted the HDRI, and now it crashes.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            There might be something wrong then.
            Is there a chance to send us the scene before and after the convert so we could investigate what's going on?
              Yes, I'll do that later today
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
