DR failing, plugin issue? help?
  • DR failing, plugin issue? help?
    im trying to use DR on a scene ive just received. it gives errors about multiscatter missing when it loads, but it doesnt matter for my purposes. however DR isnt working with this scene. i can see the spawner loads the scene partially, then max bombs out (on the slave) it then tries again.. and again.
    is it likely to be a missing plugin error causing this, or is it likely something else?
    simpler scenes work fine with DR.
    DR shouldn't fail because of a missing plugin, it might generate incorrect result because of that but it should work after all.
    Which V-Ray/3DSMax version is that?
    Does it work fine if multiscatter objects are removed from the scene?
      I tracked the issue down to a single xref. Strangely one containing a handful of editable meshes with a single multisub of normal vraymaterials. Nothing odd about it.
      I collapsed the meshes into one and merged it into a new file, and tge problem went away. Was very odd because it was fine on the host machine, and the two machines are practically identical.
        Probably this X-ref scene contains some materials or data created by additional plugin even if they are not used/applied to the scene geo.
        We will need the files in order to find what exactly is happening.
        Tashko Zashev | chaos.com
          i can probably send over the problem xref.. ill test if it causes the problem as a stand-alone file too. i cant really send over the whole project.. especially since ive resolved the issue to my satisfaction here. however if the scene might be useful to you ill fire it over.
            That would be great.
