Something strange started happening with lens effects that I don't think happened before installing Vray 3.30. When I load images from the History panel that were rendered with lens effects, they get darker a second after I load them. Please check the images below. At the left is the image how it's supposed to look and to the right is how the image looks a second after it's loaded from History. If I render the images from scratch, there's no such problem. It's only when I load the renders from history when this darkening happens. Any help is appreciated.
Lens effects make renders very dark
Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 3090 24GB + GPU Driver 566.14Tags: None
Actually we just fixed an issue that looks very similar to the one you are facing now.
http://forums.chaosgroup.com/showthr...=bloom+element
http://forums.chaosgroup.com/showthr...+effects+gamma
Probably it's the same thing, but we will need a scene to confirm that.
Looks like a similar problem, yes. Please find attached the scene from my example. I've stripped it of almost every object except for the walls, floor windows etc. I hope this doesn't affect testing.
lens_effects_derkening.zipAleksandar Mitov
96GB DDR5
Thank you for uploading the scene file Alex.
This is a different issue related to the color mapping/exposure settings and V-Ray lens effects. When loading an image from the VFB history and Lens effects (bloom or glare) are enabled the image is being color corrected again with the exposure settings used for the last render. Hope we can fix it soon.
Great to hear that you've pinpointed the problem.Is there a workaround until the fix is implemented?
Aleksandar Mitov
96GB DDR5
Got it, thanks!Aleksandar Mitov
96GB DDR5
Just to check , is this fix in the latest build of VRay 3.30.04? I sent a render with bloom and glare on before I knew of this issue and it has come out darker that it should have. Which is the opposite of the previous posters problem. But I have checked it after reading this and when I turn bloom and glare off, my VFB returns the correct colours.
Cheers.
Originally posted by andy_butler_7 View PostJust to check , is this fix in the latest build of VRay 3.30.04? I sent a render with bloom and glare on before I knew of this issue and it has come out darker that it should have. Which is the opposite of the previous posters problem. But I have checked it after reading this and when I turn bloom and glare off, my VFB returns the correct colours.
Cheers.
I re-sent again last night and the only problem (although I'm not blaming VRay as I'm not sure if it's the cause) is the bloom and glare elements did not save. I am tile rendering through Deadline and just to complicate it even more, sending the renders through RPManager.
Are there any known issues with the elements not saving when tile rendering? the reason I ask is because I can't add the Bloom and Glare elements in to my elements list, so I wonder if they don't get saved because they are not in the list.
There are on in the VRay frame buffer though. Any thoughts?
Hi Andy,
I don't have RPManager here to perform a test with the same configuration, but I did one using Deadline tile rendering and Lens Bloom and Glare (VFB lens set to render elements only) was saved successfully.
The problem might be in the RPManager setup, so please try to run a test without it.
My setup is / Max 2016 / V-Ray 3.3 / Deadline 7 /
The job was submitted through 3DS Max Deadline submission script and VFB Separate render channel was used to output the TIF files and all render elements.
If I've missed something from your steps please let me know and will start another render job.
Aleksandar Mitov
96GB DDR5
