New adaptive sampling algorithm
  • New adaptive sampling algorithm
    after quite a bit of testing of the new SP3 update I found that the new adaptive sampling algorithm is problematic with some scenes, no matter how much I lower the noise threshold I still get a certain amount of undesired grain in my renders.
    so far disabling the new adaptive sampling algorithm via maxscript has been the only solution.
    (renderers.current.twoLevel_adaptiveMethod=0)
    My particular scene has a large amount of IES lights I've always had to use significantly more subdivs on those lights to get clean renders, I don't know if this contributes to the problem.
    I'm using subpixel-mapping OFF and recommended setting per the "Cheatsheet: How to get a Cleaner image with SP3" thread.
    "I have not failed. I've just found 10,000 ways that won't work."
    Thomas A. Edison
    If you can get me any scenes to vlado@chaosgroup.com it will be very helpful to see what's going on; it might not be an issue with the sampler itself, but with the IES lights, as you noted.
      I sent you the scene.
      The left side has the new adaptive sampling algorithm on and the right side is off. That's only difference in the renders.
      Thomas A. Edison
        Hi Vlado,
        I just wanted to check and see if you had a chance yet to check my scene.
        Thanks,
        -E
        Thomas A. Edison
          i have the similar problem.
            Do you have probablistic lights enabled?
            Chris Jackson
            Shiftmedia
            www.shiftmedia.sydney
              Nope. IES Lights hate probabilistic.
              Thomas A. Edison
                [ATTACH=CONFIG]28179[/ATTACH]
                Just checking up...I wan to know if I'm doing something wrong I have this issues on several scenes. having to maxscript the new adaptive sampling algorithm off is a pain.
                Thomas A. Edison
                  what is your clr threshold?
                  Looks to me like it needs to be reduced slightly.
                  Chris Jackson
                  Shiftmedia
                    Dame!!! that its true... Plz improve noise for vrayies light.
                      It's on my "to do" list...
