Caustix Bug ?
  • Caustix Bug ?
    I just found a problem with the vray Caustix in Vray 3.3..
    When Turning on Caustix in an architectural scene and also using the shifter option of the max physical cam, the caustix doesent use the shifter option of the max physical cam..
    i turned on the option to see the caustix in the framebuffer while they are calculated and after this the Caustix doesnt fit the rest of the immage...
    greetings Tom
    Hmm yes, looks like a bug. Setting the Direct Visualization ON shifts the caustics to a different place in the image.
    I'm going to submit a bug report about this behavior.
    Thank you.
    Tashko Zashev | chaos.com
      No Problem...
      thank you for the fast answer... so ill switch this at calculation time off..
