different textures Gamma between local and network
  • different textures Gamma between local and network
    Hi guys, I have a weird behavior over here.
    i am rendering locally on different machines and the result is correct on all of them, as soon as I punch the renders through our smedge, the result is wrong where texture are used, they are to bright.
    I put examples:
    local render
    network render through smedge
    I am using a 2.2 gamma texture with Vray 3.30.3
    Vray EXR or not, result is different.
    I am wondering if it isn't a command line within Smedge which pass the texture with a different gamma. But before that I want to be sure it is not a Vray issue.
    Any idea ?
    Thank you,
    Tanguy
    Is this Max 2014? 2014 had a bug that would do this.
    Using VRayHDRI nodes rather that Bitmaps nodes (they are far superior anyway) will solve most issues.
      Works !
      Thank you
