VrayDistanceTex+ composite map doesn't work
  • VrayDistanceTex+ composite map doesn't work
    Hi all
    I was trying to follow this tutorial from Bertrand Benoit :
    http://bertrand-benoit.com/blog/naka...road-tutorial/
    but when I have tried to put a composite map in the Near map of VrayDistanceTex it doesn't show at all and if I use simple bitmap it works as it should, so I think it is a bug ?! .
    I can send a simple scene if you would like to .
    I'm using 3ds Max 2016 + Vray 3.30.03 .
    Thanks in Advance
    Simply, I love to put pixels together! Sounds easy right : ))
    Sketchbook-1 /Sketchbook-2 / Behance / Facebook
    Can you post the scene here?
      Yepp...same Problem here from BBB3´s tutorial...3dsmax 2016 and vray 3.30.04
      www.vis-art.de
      www.facebook.com/visart3d
        we ended up baking the distancetex map only into a bitmap to use it as a mask and it worked
        Sorry for that but I don't have access anymore to the old files ...maybe I can try to replicate the issue with a new file and post it here this weekend .
        Cheers.
