VrayMtlWrapper not transparent in RGB
  • VrayMtlWrapper not transparent in RGB
    I've used the VrayMtlWrapper many times before, but for some reason, I can't get it to work now.
    I have it all set up correctly I should think, and the alpha is correct but the RGB is not transparent the way it should.
    Look at these images, RGB, alpha and settings. A very simple scene with a dome light.
    Hope someone can help, maybe I'm just missing something obvious
    Thomas
    Hi Thomas,
    I have some questions about your setup.
    Which V-Ray version is that?
    How did you set the background image up? Or maybe this is a dome light with HDRI map ?
    Can you post the file here ?
    Tashko Zashev | chaos.com
      Your question made me realize I didn't set environment. Glad you asked - stupid mistake on my side, I simply forgot. Thanks
        Thanks, glad to hear that this helped.
