viewport/render differences
  • viewport/render differences
    hello,
    viewport and rendering is different. don´t know if its max or vray problem.
    thanks for looking in. i coul´d send the file if you want me to.
    thomes
    3dsmax 2016 sp1 vray 3-30-03
    scanline renderer also renders the same thing, so it´s i think a max problem.
      Do you have backface culling switched on for those objects?
      Kind Regards,
      Morne
        thanks for your help,
        see the absolutely wrong geometry in the back ! , not only the disappeared way in the foreground. the ground is rendered absolutely different than it shows in the viewport...not only a "normal" thing
          Your answer is a bit unclear to me. Did switching off backface culling reveal the bad geometry in the viewport or are you still faced with the same issue?
          Kind Regards,
          Morne
            both "off"
            collapsing the stack dissolves the issue...
              Throw an Editable Poly modifier on it, select all faces, and the click "Retriangulate" in the Editable Poly modifier options.
                thanks travis,
                but that does not change a thing. same render error.
                  thanks travis,
                  It might be a good idea to attach the scene so we could check what's going on.
