got more noise with v3.3.04 than 3.3.03
  • got more noise with v3.3.04 than 3.3.03
    I get more noise in really bright areas with vray 3.3.04 http://c2n.me/3uxdoXN.png
    with vray 3.3.03 I got this... http://c2n.me/3uxf3CD.png
    I have subpixelmapping enabled and read there will be less noise with the new release, but...
    any ideas what happens or how I could avoid the noise?
    thanks
    themaxxer
    Pixelschmiede GmbH
    www.pixelschmiede.ch
    So the colour threshold value has changed - it's number used to represent the amount of accuracy you want in your sampling using rgb values, the new version of it is now a percent. Percent accuracy needs smaller numbers to be a similar level of accuracy to the old colour based version so you'll need to go a bit lower on the colour threshold.
      It seems there might be some remaining issue there. I'm still looking into it.
      Can you post that part of the scene, just to make sure that my fixes work?
        hello vlado
        here you can download the part of the scene...
        https://dl.dropboxusercontent.com/u/57470220/noise.zip
        hope this helps...
        thanks
        themaxxer
        Pixelschmiede GmbH
          I have tested it in another scene and I get a lot of noise and fireflies... I have to downgrade...
          even with subpixelmapping disabled I get these artifacts and noise...
          best regards
          themaxxer
          Pixelschmiede GmbH
            I reproduced the issue and forward it to the developers. We'll get back to you when we get any update from them.
              nice to read, thank you for your effort.
              best regards
              themaxxer
              Pixelschmiede GmbH
                this has not been fixed in the current release?
                best regards
                themaxxer
                Pixelschmiede GmbH
                  The issue is still in the queue. As soon as we have any update we will let you know.
