Displacemet and Embree - Edge length 1 or less is no no
  • Displacemet and Embree - Edge length 1 or less is no no
    So if I set my edge length to 1 (or less), the pc stands still at the embree raycast accelerator stage. Max reads it's only using about half my RAM, but the hang is so bad, I can't even move the mouse.
    I don't know what it is doing during this time, but the hard drive goes nuts. Caching to disk?
    Kind Regards,
    Morne
    1! Good grief. I have been raising mine to 8 and checking static geometry, which renders out fine.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      Have you tried turning off Embree? You might have stumbled across something.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        I was going to ask that too...
          I'll give it a try in the morning. Just as another note, in the stack, below VRayDisplacement and below UVMap, I've tried adding a subdivs modifier and set it to VERY SMALL. I've also tried same with the Quadrify modifier and the mesh is then so dense that in wireframe it looks SOLID in the viewport. However, with or without subdivision and with or without quadrify, the actual render result doesnt seem to make any difference
          Kind Regards,
          Morne
