RT: Switching OFF Gi doesnt work
  • RT: Switching OFF Gi doesnt work
    Like the title says, If I use RT in production mode, switch off GI and render, it still calculates LC
    3.30.04
    Kind Regards,
    Morne
    OK what am I missing here?!?
    I now added an override material, and that also is getting ignored by RT!
    Kind Regards,
    Morne
      i know that rt gpu -always- uses GI. to be honest im not sure why, or why there is an on/off switch in this case.
        Will remove it to avoid this confusion.
          and the override? Is that suppose to work or not?
          Kind Regards,
          Morne
            I'm not sure about that, I have to check it out.
              Where did you set the Override material for the Production ? In Global switches or ?
              Peter Matanov
              Chaos
                Hmm ok nevermind. Looks like it has something to do with RailClone Pro, override works on everything, but Railclone renders with it's actual material
                Kind Regards,
                Morne
                  Yes, will fix it.
