Bug? Animating VrayAmbientLight intensity has no effect
  • Bug? Animating VrayAmbientLight intensity has no effect
    Hello,
    I have just come across something that might be a bug. To reproduce:
    - Create some geometry to test with (plane, teapot)
    - Create a VrayAmbientLight
    - Animate its intensity from e.g. 1.0 to 0.0
    - The value itself in the modify-tab counts down just fine
    - The rendering stays the same throughout the whole animation
    As a workaround the color could be animated instead, this works.
    Tried with Vray 3.30.05 in 3ds Max 2016.
    Is this a bug or intended behaviour?
    Thanks,
    Bob
    It doesn't work here also, it is a bug which I am going to report right away.
    Glad to hear you have already found a workaround.
      Thank you for testing, it is always nice to know that it is not only me having the problem.
