When using DR the main render workstation renders slightly differently
  • When using DR the main render workstation renders slightly differently
    I've never had this issue before. It's normally the other way round if there is a DR bucket issue. I've checked all maps are network accessible. Not really sure what is going on here ?
    Regards
    Steve
    My Portfolio
    I think this is a richdirt 2 issue. For some reason the patterns are very slightly different. I've made sure the same version is on the all machines. I'll contact the author of Rich Dirt 2
    Regards
    Steve
    My Portfolio
      Hi Steve,
      Probably it generates different pattern for each 3DS Max instance. It is only assumption.
      Tashko Zashev | chaos.com
        I had that issue with bercon maps. You have to install it on all slaves as well. UNC didn't help. Installing the plugin on slaves solved the problem.
          Does the issue disappear if RichDirt is removed completely from the scene?
