Vray 3.30.05 stops working midway (3DS Max 2014)
  • Vray 3.30.05 stops working midway (3DS Max 2014)
    My machine has recently had all it's software and OS reinstalled, so a very clean machine. Currently working on a project since then and I'm experiencing intermittent connection with V-Ray.
    I'm not too up on the Services and Processes side of things, and not a big fan of Dongled software either (all stuff I don't know too much about) - but as far as I can tell, the VRLService is running, during the failure VRay (what happens is, is that I'll be working fine in 3DS Max, using VRay fine, then after about 20mins or so, VRay will no longer be working and I'll shut down and restart 3DS Max, whereby I'm told by VRay that "Could not obtain a Licence (-197)".
    If I restart the computer, I can go into 3DS Max and start working again (for around 20-30mins).
    I looked at Control Panel "WiBuKey" and it struggled to find anything and reported "wibuke64: fatal error wk1204 - wibubox with bad version".
    I've looked at WiBuKey drivers and note that the last one on their site is July 2015, so I've downloaded that and will update ?
    Could my Dongle have developed a fault ?
    (my dongle is physically inside my PC case, so it doesn't get touched / disturbed in any way).
    Any ideas please ? (I did submit a ticket but this is happening too often now and constantly restarting my computer each time is wasting me time).
    Many thanks.
    Jez
    3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
    Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
    Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
    ---- Updated 06/09/23 -------
    hmmm, yeah dongle softwares are a nightmare sometimes, i remember one company i used to work each year we needed to change the dongle, was alot of issues with the cnc machines, maybe its the housing for the usb gone bad?
    Architectural and Product Visualization at MITVIZ
    http://www.mitviz.com/
    http://mitviz.blogspot.com/
    http://www.flickr.com/photos/shawnmitford/
    i7 5960@4 GHZm, 64 gigs Ram, Geforce gtx 970, Geforce RTX 2080 ti x2
      I have a similar problem with my dongle (at least I suppose it's a dongle fault, since it's a really old one). What I do is, when V-Ray stops working, I simply remove it for 3 seconds and plug it again. No need to restart Max nor anything, just make sure the Render Setup window is closed.
      V-Ray Evangelist, Trainer and Freelancer
      www.behance.net/rickeloy
        i got similar problem with my x99 board too, but after adjust some setting at bios, the problem solved, u can try disable the XHCI and EHCI Hand-off function at bios.
        www.archcg.my
          Thanks everybody.
          If you asked me to guess, right now, I'm more inclined to believe it is a BIOS setting first, followed by a USB/mobo issue (really hope it's not that!), followed by perhaps a dodgy dongle.
          I'll check my bios settings, and see if that fixes things.
          Jez
            for now we can wish in the future that the dongle system will change, a friend of mine lost his last year and because he didn't use it much he didn't even bother to replace it, so tiny
              I had this problem when I slot it in USB 3.0 port, works fine with 2.0
              Best Regards
              Tomek
              Portfolio: http://dtown.pl/
                This looks like a WiBu-Key drivers issue, please follow the WibuKey troubleshooting guide bellow to re-install the drivers:
                http://docs.chaosgroup.com/display/V...YDriversIssues
                Make sure also that you are using the latest version of V-Ray License server:
                http://www.chaosgroup.com/en/2/downl...license-server
                  Thanks everyone for their input.
                  The issues were several fold;
                  1) I had old Wibukey drivers (why I don't know because this is a fresh machine with newly installed software, including v-ray 3.30.05 which I'd have thought would have the latest wibu drivers).
                  2) Ditto above re. Licence Server
                  3) There was a Windows Hotfix which was causing an issue as well (with uninstalling wibu and possibly was conflicting with wibukey as well).
                  Like Tomek, I think I might have an issue with USB on my mobo - it's just a hunch but for example I have found that my preferred mouse (a Sharkoon Fireglider) does not like being used in a particular USB port and does occasionally cause my machine to freeze on Windows startup......(when I use my very basic, but very trusty Microsoft mouse I have no such issues whatsoever).
                  Anyways, thanks to the fantastic support at Chaosgroup for sorting me out
                  Jez
                    Glad to hear that everything works fine now and thank you very much for your generous words and detailed feedback
