VRay and maxscript issues
    like tmp = for i = 1 to numEffects collect (getEffect i)
    result:
    #(VRay_blah:nameOfVRay_blah)
    tmp = for i in tmp collect (copy i)
    result:
    #(undefined)
      just tried with Lens_effects and it works, so it is a Vray render effects problem
        sorry, no it doesn't work at all
        Max refuse to copy render effects
        I will try to find a way to get the subanim object as a workaround...
          just test
          copy rootScene.Render_Effects[1]
          no workaround....
          Please help if you can!!!
            Untested, but this might work in some cases, it creates copies of the underlying ParamBlock2's and puts them in a new identical effect:
            Code:
            fn copyEffect effect =
            	local ef = (classof effect)()
            	local deps = refs.dependsOn effect
            	for r = 1 to deps.count do
            		if (isKindOf deps[r] ParamBlock2) do
            			refs.replaceReference ef r (copy deps[r])
            	ef
            Then again, might not work in other cases, like effects with non PB2 dependencies.
            • #21
              Left work already. I was actually thinking of a workaround by creating a new effect, copy/paste the props of the old one, copy the new one and delete it to have only one instance in the CA
              • #22
                Thanks a lot for the help!
                • #23
                  It almost works, very interesting this refs thing...
                  but if the number of PB2 is different it doesn't, without sending any error.
                  For example lens effect is adding a NEW block with each element you add to it.
                  Ok I give up on that for now, not super used anyway but frustrating.
                  The help file is stating in little font at the bottom of the page:
                  NOTE:
                  Unlike most MAXWrapper objects, you can not copy a RenderEffect.
