How do I use Complex Fresnel shader with http://refractiveindex.info/
  • How do I use Complex Fresnel shader with http://refractiveindex.info/
    Hi guys,
    Im learning a lot about V-Ray by building materials. Does anyone know hoe I extract the n and k values of a material from http://refractiveindex.info/ ?
    Would be a great help to me as Im trying to make many material presets.
    You need the wavelengths corresponding to R, G and B. Then write down n and k for those. SO on the top there's a box where you can input the wavelength, it will give you the n and k values for that specific wavelength.
    This is the somewhat loose part because what exactly is the correct wavelength for computer R, G and B?
    For example (wavelength, n, k)
    GOLD
    0.61136 µm 0.22213 3.0363
    0.54896 µm 0.42814 2.3340
    0.46428 µm 1.2570 1.7531
    edit: changed from nm to µm.
    Rens Heeren
    Generalist
    WEBSITE - IMDB - LINKEDIN - OSL SHADERS
      YES! Thank you. Yeah I just Wikied R, G, and B...then I saw your post and it confirmed my suspicions. Sweet! I love V-Ray. Thanks again for your help.
        Glad it works!
        Rens Heeren
        Generalist
