Here is an image I'm working on that's doing some weird stuff. It doesn't matter if I send the job to BB, or use DR from my workstation, same results. At the point at which I did the screen grab, the network nodes were all on standby (0% CPU). Not sure what's going on. So for the moment, I'm doing a progressive render and that seems to be working for me. This happened once to me before, but I can't find the post or remember what was causing it. Quite odd, and unsettling.
Holy buckets, Batman! - Part II
David Anderson
www.DavidAnderson.tv
Software:
Windows 10 Pro
3ds Max 2024.2.1 Update
V-Ray GPU 6 Update 2.1
Hardware:
Puget Systems TRX40 EATX
AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
2X NVIDIA GeForce RTX 3090
128GB RAMTags: None
Originally posted by vlado View PostWhich V-Ray build is this? Next time it happens, look at the vraylog.txt file on the render slaves and see if there is anything meaningful there.
Remind me again where the log file is? I looked in AppData.David Anderson
Software:
Windows 10 Pro
Hardware:
128GB RAM
I just checked. See attached. No Weirdness found.vraylog.txtDavid Anderson
Software:
Windows 10 Pro
Hardware:
128GB RAM
Is there a way to tell Vray how many logs to keep?David Anderson
Software:
Windows 10 Pro
Hardware:
128GB RAM
Windows 10?Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Originally posted by glorybound View PostWindows 10?Or were you saying I should upgrade??
David Anderson
Software:
Windows 10 Pro
Hardware:
128GB RAM
I would tell you to kill the runtimebroker gremlinBobby Parker
phone: 2188206812
- Windows 11 Pro
We have started seeing this. It seems to be one node that gets stuck and then everything goes a bit crazy like the image posted.
Only happens with DR though, and you can fix it by just finding the problem node and removing it from the DR properties on the rendering dialog box at the bottom.
I've had a look at the log file and it only gives an error about not being able to delete the server scene file.
Seems to be just one scene that is doing it for me. Upgrading to 3.4 didn't fix it. I ended up going "progressive" on it. That seemed to work.David Anderson
Software:
Windows 10 Pro
Hardware:
128GB RAM
its probably because your dr slaves have crashed, or failed to begin rendering. Switching to progressive probably used your main workstation to render the scene.
its likely because either there is a missing plugin, or a different vray build or something like that which is preventing them from running.
having said that though, I've had a scene not long ago where from 22 machines 4-5 machines would render then crash, then start rendering again, do some buckets then crash and like that in the loop until the image was done. Though the rest of them rendered fine without crashing.Dmitry Vinnik
Silhouette Images Inc.
ShowReel:
