Cubemap Stereo rendering wrong aspect ratio
  • Cubemap Stereo rendering wrong aspect ratio
    If you render a 6 x 1 cubemap in stereo mode it only renders every cube as a half-width cube instead of a full width cube. Is that an option somewhere you can disable to do a 12x1 instead of a 12x1 anamorphic in a 6x1 aspect ratio?
    Gavin Greenwalt
    im.thatoneguy[at]gmail.com || Gavin[at]SFStudios.com
    Straightface Studios
    There is an option Adjust resolution in the V-Ray stereoscopic settings. It will automatically adjust the render resolution from 6x1 to 12x1
    Tashko Zashev | chaos.com
      Originally posted by tashko.zashev View Post
      Thanks, that somehow got disabled. I'm pretty sure it's usually on by default.
      Gavin Greenwalt
        it's not, always needs changing with a new helper
