no bitmap preview
no bitmap preview
Architectural and Product Visualization at MITVIZ
http://www.mitviz.com/
http://mitviz.blogspot.com/
http://www.flickr.com/photos/shawnmitford/
i7 5960@4 GHZm, 64 gigs Ram, Geforce gtx 970, Geforce RTX 2080 ti x2Tags: None
Originally posted by RotemS View PostProbably an asset resolving issue. Check the asset tracking dialog when you open the file and check where the bitmap is pointing.Architectural and Product Visualization at MITVIZ
Originally posted by vlado View PostDoes the same happen if you open the file on a different computer? If yes, maybe we should take a look at it.
VladoArchitectural and Product Visualization at MITVIZ
I had this issue a million times already, I don't think it's Vray related. The only thing that helps is delete the bitmap node and create a new one.
Originally posted by Vizioen View PostI had this issue a million times already, I don't think it's Vray related. The only thing that helps is delete the bitmap node and create a new one.Architectural and Product Visualization at MITVIZ
Originally posted by Art48 View PostI had this, too. In some cases it helped to "Reload" or to "View" the image inside max.Architectural and Product Visualization at MITVIZ
Originally posted by svetlozar.draganov View PostHave you tried to convert Bitmaps to V-Ray HDRIs and see if it is better or not?Architectural and Product Visualization at MITVIZ
Originally posted by mitviz View Postno i haven't, manually each bitmap you mean? i have always wondered what are the benefits of using the hdri loader instead of the regular bitmap loader for loading regular images
Originally posted by Vizioen View PostRight click > convert bitmaps to vray hdri does it for all the bitmaps. I thought vray HDRI has better filtering and I've read that it might be faster in loading too, but not quite sure. Since Vray HDRI supports real world scale display in viewports I never use a regular bitmap anymore.Architectural and Product Visualization at MITVIZ
another thing i ran across though few times which i never checked was when viewing very large maps with the hdri loader its very blurry compared to the standard bitmap loader which gives near correct results, any reason why?Architectural and Product Visualization at MITVIZ
Originally posted by mitviz View Postanother thing i ran across though few times which i never checked was when viewing very large maps with the hdri loader its very blurry compared to the standard bitmap loader which gives near correct results, any reason why?
VladoI only act like I know everything, Rogers.
