Crash when rendering proxy with no filename.
  • Crash when rendering proxy with no filename.
    VRay will crash when trying to render a VRayProxy object for which the 'filename' property is set to 'undefined'. Attached is a scene file containing such a specimen.
    I am not sure how it became this way, I see that if I create a new VRayProxy object and don't give it a file, then the 'filename' property is set to "", and in this case VRay does not crash. The attached object came from a scene likely created in an old version of VRay.
    Also, VRay 3.20 does *not* crash when trying to render the attached object.
    Tested on max2014 and 3.40 nightly #26831.
    invalid_vrayproxy.zip
    Thanks, will fix it!
