Denoiser erase the rest of the frame when doing render region
  • Denoiser erase the rest of the frame when doing render region
    When doing a render region over a preceding render, the denoiser erase to black the rest of the frame instead of keeping it like all other elements do. Would it be possible to change that behaviour please?
    __________________________________________
    www.strob.net
    Explosion & smoke I did with PhoenixFD
    Little Antman
    See Iron Baby and other of my models on Turbosquid!
    Some RnD involving PhoenixFD
    This has come up before and they know about it.
    WerT
    www.dvstudios.com.au
      ok great thanks!
      www.strob.net
      Little Antman
        I think you can just uncheck "region render" from frame buffer and hit update, as all the other elements there for denoiser to do its job ?! I need to try that later, But for sure fixing it in the first place would be better s
        Simply, I love to put pixels together! Sounds easy right : ))
        Sketchbook-1 /Sketchbook-2 / Behance / Facebook
          Ok yes didn't think about that worth a try. thanks
          www.strob.net
          Little Antman
            I would also like to request that DeNoiser respect the region render and retain the prior contents of the VFB. PLEASE PLEASE PLEASE!
            John Pruden
            Digital-X
            www.digitalxmodels.com
            3D Model Marketplace
              Yes, will change this.
                You guys are the best! Thanks Vlado!
                John Pruden
                Digital-X
                  A year and a half later and this hasn't been fixed yet? Wow.
                  - Geoff
                    Actually this should be fine since a long time. If you still have issues, can you describe what you are doing?
                      * Render a scene into the VFB
                      * Nice
                      * Render just a region of it
                      * Only the region renews.
                      * Nice
                      -- Load a denoiser render element
                      * Render the scene again
                      * Nice
                      * All but the region turns black while the region renews.
                      * Not nice.
                      I am using VRay 3.60.04 on Max 2016
                      Thanks.
                      - Geoff
                        Actually I see it's fixed in the beta of Vray 4. The image outside of region renders no longer turns black if the denoiser is used. Thanks for fixing this. It was a bit of a pain for every region render to turn off the region, go back in RE, click on Update and then wait once more for the image to be denoised.
                        Aleksandar Mitov
                        www.renarvisuals.com
                        office@renarvisuals.com
                        AMD Ryzen 9 9950X 16-core
                        96GB DDR5
                          The original issue is not quite fixed and I'm scratching my head what to do about it; it works fine if you run the denoiser with the "mode" option set to "Show denoiser result channel" *before* saving a .vrimg or OpenEXR file, but the default value is different and causes the issue.
