vray light directional parameter visible light issue
  • vray light directional parameter visible light issue
    hi there,
    iv run into a problem using the directional parameter and lighting maintaining their visibility.
    ideally i would like them to remain visible even when the directional parameter is enabled. i want to do this to be able to use the glare pass from the light source
    below is images of disc lights with 0.0, 0.25, 0.5, and 0.75 directional parameters increased. is this a bug or expected behavior?
    cheers
ID:	885062Click image for larger version
ID:	885063Click image for larger version
ID:	885064Click image for larger version
    edit - also with vrayenv fog off i get the same behaviour
    The help pages say that this is expected behavior. I could suggest a workaround:
    Create duplicates of your lights and then make their "Directional" parameter value 0.0 and disable the checkbox "Affect Diffuse". Then in your original lights disable the checkboxes "Affect Specular" and "Affect Reflections". This way you will have visible reflections and speculars since the original lights won't produce them anymore if the Directional parameter is used.
    Let me know if this worked.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
