VFB Load images bugs
  • VFB Load images bugs
    Hi all
    1)
    When loading a VRIMG file that was saved with lens effects, the VFB goes nuts and the RGB channel results in some nuclear image. All other channels are fine, just the RGB beauty is a mess
    2)
    Trying with a multichannel EXR doesnt work as it loads only the RGB and Alpha channel and ignores the rest.
    The reason I'm loading the images in the VFB, is because I want to adjust the lens effects after the fact, but this seems an impossible task with the VFB
    Kind Regards,
    Morne
    Will fix both of those, but #2 should still work if you want to apply lens effects - load the EXR and enable the lens effects and adjust as needed - you can then save the RGB separately. Obviously it will be one more file to drag along with the original image, but it should be fine.
      ...but #2 should still work if you want to apply lens effects - load the EXR and enable the lens effects and adjust as needed...
      That doesn't work. As soon as enable lens effects, red labels are added in the lens effects saying "No channel, please re-render"
      no matter what mode it is on
      Kind Regards,
      Morne
        Strange, just tried on another vrimg file, and it seems to be working, even with the denoiser. But it's very fussy...
        Kind Regards,
        Morne
          But I kinda need it to work with and EXR, not a VRIMG...
          Kind Regards,
          Morne
            Is there a way to convert a multichannel EXR to a VRIMG file?
            Kind Regards,
            Morne
              This will happen if color mapping is different from default in the current renderer settings (i.e. burn is different from 1.0 etc).
                Yep, I'm aware of that... we will need to change some things in the lens effects implementation to make it work seamlessly with the denoiser.
                  How far from the top on the priority list is this? Lens Effects has been in VRay for years, but half its features aren't working. Will this be removed at some point or will it work one day? Things like this as well as the intensity masks etc...
                  VRay is great, but there's things like these that hang for years and seem to never get fixed.
                  Kind Regards,
                  Morne
                    As you have guessed, not terribly far up.
                    Most of them are actually working. There are only a few options that don't.
                    No.
                    Yes.
                    It happens, unfortunately, as much as we try to be on top of everything.
                      OK thanks for the update Vlado. You guys do great work in general. For now I'll see what I can do with it as is
                      Kind Regards,
                      Morne
                        Hi V-Ray team
                        Has the loading of multichannel EXR into the VFB been fixed yet? If not, is there an internal build or something where it works that I could get my hands on?
                        Kind Regards,
                        Morne
                          No, not yet, I'm afraid.
                          Alex Yolov
                          Product Manager
                          V-Ray for Maya, Chaos Player
                          www.chaos.com
                            OK thanks Alex. Please keep us posted
                            Kind Regards,
                            Morne
