[Maxscript] Error assigning light array to VrayEnvronmentFog
  • [Maxscript] Error assigning light array to VrayEnvronmentFog
    Code:
    fog_lights = #($'FOGLIGHT_Nav-Green', $'FOGLIGHT_Nav-Red', $'LIGHT_Nav-L', $'LIGHT_Nav-R', $'FOGLIGHT_Beacon-Bottom', $'FOGLIGHT_Beacon-Top', $'LIGHT_Strobe-L', $'LIGHT_Strobe-R', $'LIGHT_Strobe-Tail')
    (getAtmospheric 1).lights = fog_lights
    That script gives me the following error 90% of the time. Sometimes it works and once it does, I don't get the error anymore in that scene. Can't figure out what's going on but it feels like some kind of read only thing?
    Code:
    -- Error occurred in anonymous codeblock; filename: ; position: 727; line: 16
    -- Runtime error: Assignment failed, possible dependency loop, $VRayLight:FOGLIGHT_Nav-Green @ [-2013.063232,420.178894,67.097580]
    I had a similar problem with VraySphereFade, when trying to set the array of gizmo.
    it worked a couple of times but most of the time it was crashing 3dsmax...
    Similar in that accessing Array inside an Atmospheric...
      Hello VRaySphereFade.lights is an array, so there seems to be some problem with it we should look into. Currently you can append single objects like:
      Code:
      append (getAtmospheric 1).lights fog_lights[1]
      for example.
      Alexander Kazandzhiev
      V-Ray for 3ds Max developer
        Code:
        for example.
        Okay. Thank you.
