Vignetting doesn't work when Glare/Bloom is enabled
  • Vignetting doesn't work when Glare/Bloom is enabled
    As the title says. I can't see vignetting if I've turned on Glare, Bloom or both. I tried even setting Vignetting to an extreme value of 10.0 but still doesn't work. I see it while Vray renders (progressive) but once the render finishes, Vray applies the bloom & glare and the vignetting I was seeing before disappears. Is this to be expected? For specs please check signature.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    It looks either as a bug or as something not supported.
    Will add a note about it into our system and will keep you posted.
      Thanks for looking into it.
      Aleksandar Mitov
      96GB DDR5
        For some mysterious reasons this bug disappears when rendering with Subpixel Mapping ON.
        This could be used as a temporary workaround until being fixed.
          Thanks for the tip! So it's not unsupported feature. In this case hopefully it's something easy to fix.
          Aleksandar Mitov
          96GB DDR5
            I can happily confirm that with Vray 3.5 Beta this problem seems to be fixed!
            Aleksandar Mitov
            96GB DDR5
