Weird topology problem.... object in viewport shading destroyed by changing segments
  • Weird topology problem.... object in viewport shading destroyed by changing segments
    Okay, this problem just started. I am thinking it might be related to Max 2017 Service Pack 3 but I'm not sure.
    Here is what I did....
    Vray is my current renderer.
    In a fresh scene, I created a sphere with 32 segments.
    I hit Render.
    Then I went back and lowered the number of segments. The sphere starts to look really weird in the shaded viewport. It renders weird too. If I change the # of segments back to 32, everything is fine. Adding an Edit Poly modifier will also fix it.
    Is this happening to anyone else? This does not happen when I am using the Scanlline renderer (I just tested it -- but I never actually use Scanline).
    I've attached the file if someone wants to see what I'm seeing.cylinder normals problem.zip
    I hit Render.
    I've attached the file if someone wants to see what I'm seeing.[ATTACH]33258[/ATTACH]
    Does it look like this? http://forums.chaosgroup.com/showthr...823#post695823
    A.
    www.digitaltwins.be
      Yes that looks like the same issue. Thanks for pointing out that thread.
