Hi all
I have a render farm set up using other designers nodes. We can set the affinity of the render nodes to only use 50% (ie one of the two available Xeons on their machines) This allows us to distribute-render through the day but also gives the designer on the node the ability to do other tasks without 100% of the CPU being used.
This works when setting one frame rendering as you go into task manager and set the affinity to use only one Xeon, the problem is that for every frame on say an animation, vrayspawner resets/relaunches which also resets the affinity.
Is there a way to throttle the usage of independent nodes so that the full 100% isnt used on a sequence of animation frames as opposed to on a frame by frame basis?
Hope this makes sense
thanks!
thanks!
